Upgrade Navi Display from Phase1 to Phase2
  • Hi guys ,like i write in the title i want to upgrade my navigation display from old one to new version ,i have talisman sedan from 05.2020,i don't have wireless carplay or android auto ,new update from maps ,etc,i found on ebay some navi from megane 4(i think it's talisman phase2) and i want to buy,i heard that i need to upgrade and multimedia unit radio ,i don't know exactly, and i want to change in future and speedometer, also from phase2. Can someone help me with some info,if it's a good ideea or not,why? etc if it's compatible with my car. Thank you and have a good night. ;)
    RENAULT TALISMAN INITIAL PARIS BLUE dCi 200 EDC, Interior: Harmony Titanium Black, Fuel: DIESEL, Color: Crimson, Gearbox: AUTOMATIC TRANSMISSION 6 RATIO, Sunroof panoramic.
  • Hi Alex. I think is better to contact NeeK because he is selling Easylink without VIN. I think you want to change from RLink2 (Talisman PH1) to Easylink (Talisman PH2) and for that you need to contact NeeK. He knows more than I do.
    Talisman Grandtour Ph2, IP, 2.0 dci 190 PS
  • Hallo Alex,
    There is no official way to install EasyLink in a vehicle with R-Link2. The systems are also not compatible with each other. It is not impossible, but the effort involved is very high.
    Regards
    Es gibt keine offizielle Möglichkeit, EasyLink in ein Fahrzeug mit R-Link2 einzubauen. Die Systeme sind auch nicht miteinander kompatibel. Unmöglich ist es nicht, jedoch der Aufwand ist sehr hoch.
  • Hello ny.newyork ,
    I just want to change/upgrade RLink2 to EasyLink, navi,only this for the moment, i will contact NeeK for price and installation, and I have to go to Renault for some maintenance to sunroof and I will speak with them also to see if it’s possible. Can I make android auto or CarPlay to work now on RLink2 without usb cable? Thank you guys.
    Thank you for answering to my quest 🙏 You are all welcome to help me with advice and everything
    Einmal editiert, zuletzt von AlexCA ()
  • Hallo Alex,
    Renault cannot support a conversion because only what is entered in the configuration server for the VIN works. Free programming is not possible with the workshop systems.
    It is easier to install a new Gen2.1 radio with R-Link software version 9.0.37.21x and use a USB wireless adapter.
    Renault kann eine Umrüstung nicht unterstützen, da nur das, was im Konfigurationsserver zur VIN eingetragen ist, funktioniert. Frei Programmieren ist mit den Werkstattsystemen nicht möglich.
    Einfacher ist der Einbau eines neuen Radios Gen2.1 mit R-Link-Softwareversion 9.0.37.21x. und Verwendung eines USB-Wirelessadapters.
