I found today after i remove a pannel that i have connection but i have the button block(hidden)
If i change with a pannel with all functional buttons will work or i need to plug and under the bord? Thank you and have a nice day
I assume that Renault uses the identical wiring harnesses for different trim levels.
You don't automatically get functions that your car doesn't have by replacing the panel and connecting the buttons.
The second button on the right, for example, is for opening and closing the trunk lid. If you don't have an electric trunk lid, it won't automatically become one just because you connect the button.
I understand,thank you very much.
Hallo Alex,
as a rule, only what is stored in the configuration server for the VIN works.
Regards
In der Regel funktioniert nur das, was im Konfigurationsserver zur VIN hinterlegt ist.
I understand, i will stay calm then😅
