Aktuelle RLink2 Version V9.0.37.21x
  • OK, then you have to update to V9.0.34 or V9.0.35 first. Another user in our forum just had the same problem as you. I gave him the tip to first go to 9.0.34 and then to 9.0.37. It's working for him now. You can get V9.0.34 here:
    https://mega.nz/folder/6ZNywAI…r37P7zkWw/folder/6d8gxS5Y
    The installation procedure is the same.
    Hi,
    you were completely right.
    After installing the file you sent a link for i could install the next one and now im updated to newest version :)
    I managed to access the developer settings and activated it under DiagRW - Gen 2.0.
    Android Auto as present.
    In the main meny i also activated Android auto projection but still no go to get AA.
    Do you have any ideas except DDT4all? Really not comfortable using that.
    Thanks again
  • For Radio Gen1.1, further settings must be made in DiagRW under Gen2.0:
    4. Find the point “DiagRW” and click on it
    5. Find the point "GEN2_0" or something similar (depending on the radio version) and click on it
    6. Then select “Present” on the right under “CarPlay” and “AAP”. If it is already selected, select it again anyway. Then go to “save” at the top right.
    7. Soft reset the radio once. Press and hold the on/off switch at the top right until the display goes completely black.
    This is how it should work.
  • Hi,
    I actually got it working yesterday, my bad for not holding the Power button long enough to soft reset the unit. I do appreciate all the help, was a lot easier then i thought it would be and im so tired of R-link that if i would to brick the unit during update, i would just buy an Google unit aftermarket to replace it with.
    All is working now tough so all god :)
    Thank you so much for the assist!
  • Hallo Zusammen,
    ich habe die Version 9.0.37.21x problemlos instaliieren können. Für den Ganratiefall habe ich die Originalversion 3.x.x. gesichert. Weiß Jemand, ob man einen Downgrade auf die Ursprungsversion machen kann?
    Hallo Nilius.
    Kannst du mir verraten, wie du deine Originalversion "gesichert" hast? Gibt es eine Backup- oder Export-Funktion?
    Oder hast du schlicht die passende Version als Updatepaket vorliegen?
    Gruß, Tobias
    1. Talisman Grandtour Ph2 BLUE dCi 200 EDC, IP, EZ 11/2020:
    Baltikum-Grau, Leder Sand Grey, VOLLAUSSTATTUNG inkl. Panoramadach und abn. AHK
    1. Talisman Grandtour 1.8 TCe 225 EDC GPF, IP, EZ 11/2019
    2. Mitsubishi Colt CZT, BJ 2008:
    Gewindefahrwerk, Spurverbreiterung, Sturz HA, PU-Buchsen Achsen/Motoraufhängung/Querlenker, Fächerkrümmer, LLK, BOV, AGA, Softwareoptimierung, Clubsport-Bügel, Zusatzinstrumente, 17"-Barracuda, Semi-Slicks
  • Hallo zusammen, ich bin seit knapp einer Woche in Besitz eines Talisman und habe am WE das Update erfolgreich installieren können. Bislang ist mir auch noch nichts aufgefallen, was nicht funktioniert. Ich höre jetzt lediglich alle paar Minuten immer mal wieder einen kurzen Piepton. Dabei wird auch kurz die Musiklautstärke runtergefahren. Ich konnte aber kein Popup oder Blinken in den Displays feststellen, also kein optisches Signal sondern nur ein kurzes "Pling". Wisst Ihr was das sein könnte? Vor dem Update war das nicht da.
    Renault Talisman Grandtour Initiale Paris ENERGY TCe 200 EDC, EZ 2018, SW 9.0.37.216
    Hallo und Glückwunsch zum Talisman
    Wenn es wiedet "Pling" macht, schau nach ob du zu schnell bist. Der Geschwindigkeitswarner....
    Renault Talisman Grandtour Initiale Paris ENERGY dCi 160 EDC
    BJ 09/2017
    Kosmos-Blau
    Innenharmonie Titanium Black
    Panoramadach
    RLINK2: 9.0.37.216;
    Ist mit hoher Wahrscheinlichkeit der Geschwindigkeitswarner. Hatte sich bei mir nach dem Update auch automatisch aktiviert. Einfach in den Einstellungen ausschalten und dann sollte alles klappen :)
    Renault Talisman Initiale Paris Cosmos Blue - Baujahr 2016 - RLink 2 Bootloader 5534 - SW 7.0.24.166; do it yourself Update auf 9.0.34.616 - HW GEN 2.1
  • Hi AndVanHand
    Glückwunsch zum Talisman IP und immer gute Fahrt !
    Willkommen im Forum 👍.
  • Ja es war der Geschwindigkeitswarner. Vielen Dank für den Tipp.
    Noch etwas ist mir aufgefallen: die Start-Stop-Automatik aktiviert sich nach dem Update sofort, sobald man auch nur mal kurz an einer Kreuzung steht um nach rechts und links zu schauen. Vorher waren zumindest gefühlt 1 bis 2 Sekunden Verzögerung drin. Kann man das einstellen?
  • Start-Stop kann per Schalter i.d. Mittelkonsole deaktiviert werden, aber nach meinen Erfahrungen nicht dauerhaft.
    Ohne sich in der Software zu vergreifen...
    vg
    Grandtour 2017
    Volvo 480<3
    Ex: Volvo c30, v 40, v 70
